To add to the original post from RPGallagher, Viper is a Motorola type II mixed mode ( analog and digital modulated voice talkgroups ) system. That will change in the future over the next couple of years, although the Raleigh / Wake simulcast sites will likely go sooner.
The Dare County system is a Motorola P25 system. The two major distinctions for a hobbyist listening to this system, compared to a Motorola type II system, are that ALL voice talkgroups will employ P25 digital modulation, and the rate of the control channel data is 9600 baud - rather than 3600 baud for a type II system.
So, RPGallagher, you need to program the Dare Co P25 sites as a P25 system. The particular system type will depend on which model of scanner you're using, and what software you program with.
Greg provided a list of status bit variations above. Their impact on scanner listeners is only applicable to Motorola type II systems. Some of the variations can be applied to other uses, but note that there are 16 variations in total ... the talkgroup in its original mode, plus 15 alterations of how the talkgroup can operate.
Those status bit variations are why you see talkgroups, when displayed in the decimal format, spaced 16 digits apart (some systems space them 32 digits apart, which leaves slots open for future use).
When you progress to a Motorola P25 system, a different method is used to pass talkgroup variations to the radios and dispatch consoles. Subsequently, P25 system talkgroups tend to be numbered consecutively, with blocks of consecutive talkgroups being assigned to the same user / agency.
Each of those variations to the original talkgroup will change the decimal I-D hobbyists normally use to identify a talkgroup. Most Uniden scanners nowadays allow users to choose whether they want the scanner to recognize or disregard any status bit variations on a Motorola trunked system.
So, if you're listening to talkgroup 12088, and another talkgroup is patched to it, the I-D or the original talkgroup will change to 12091. If dispatch employs multi-select, 12088 will change to 12095.
If your status bit variation setting for the system is set incorrectly, you will not hear either talkgroup in the above example. There are occasions when you may want your scanner to filter out variations to status bits, but 99% of hobbyists probably set the status bit variation setting to disregard variations.
( I'm not sure if the status bit setting feature on Uniden scanners would have any impact on filtering P25 system talkgroups operating in patched or multi-select mode. Any input would be appreciated. - Jeff )
