box23
I've tried searching through the forum but haven't found anything on this topic,
I've installed DarkIce in Ubuntu 9.10e with reference to the HowTo in the wiki. I modified the configuration file in the wiki as needed for my setup. However I am slightly confused as to the information needed. For the "name" field, would this be the "Primary Description" field on my Manage Feed page? Then would the "description" field be the "Secondary Description" for my feed? I don't know if this really affects anything, but I thought I should ask.
As for my real problem, when I run darkice using the -c argument to point to my modified config file, the following error pops up:
I have tried internet searches of the error, but haven't been able to come up with much information, only that the error cryptically says darkice cannot connect to the icecast server.
My computer is behind a router and I have port 80 forwarded to a different computer running a web server. Thinking this may be the problem I tried disabling that forward, and even forwarded it to my stream computer to no avail.
At the moment I can't think of anything else that I have tried, but if I remember I will post. I can also post my config file if needed.
Has anyone else seen this error before, or know how to handle it?
Thank you for any help
Code:
DarkIce: LameLibEncoder.cpp:75: lame lib opening underlying sink error [0]
