ARCXT: database
kd9dvp
When choosing a database I select My State, My county It show's Entity" Knox County trunked Systems" then Type 'Trunked". Do I select this option to send to my programming software? Will it choose all frequencies police, fire, county sheriff. etc.? Thanks
Great question, but it will get more responses in the Scanner Programming thread rather than here. Please click on report in the lower left corner of your post and ask for it to be moved. Please do not start a new thread as double posting is not allowed in the forums.
Please note, you will need to share what scanner and programming software you are using, as each one is different. Also, you can not directly import from the RR database to your scanner, you will need programming software to accomplish this.
kd9dvp
I have imported my list of talk groups. I have more than I am interested in monitoring . Before I export to my scanner how do I delete from my list? Thanks
tvengr
Well Known Member
Baltimore County, MD
Highlight a talkgroup or talkgroups you want to delete. Go to the Options tab and click on Clear Selected Line(s). Once you have eliminated everything you desire, go to the Options tab and click on Remove Empty Line(s). Make sure you save the file.
