BCD325P2/BCD996P2: Deaf BCD996P2
TongSlinger
Longtime Listener
35.393528, -99.467468
hiegtx, I set up the single frequency DMR as suggested and there is no difference in the reception. It still doesn't receive the SO from 30 miles away. it receives the the local PD.
hiegtx
Dallas, TX
When setting it up as an OFT system, did you enter each frequency as a separate site? I would also make sure that you have ID Search enabled.
I would also suggest that you post your programming file. If you created it in ARC-XT, I can't take a look (I don't use ARC-XT), but there are a number of other members that can. If you also installed ProScan for the trial period, I can look at that, and there are many others that can do that as well. If you have loaded ProScan, have you tried the file that buddrousa attached in post 16?
