k0co_5
DPD Chief just on Ch2 news explaining how they will staff up using forces from neighboring cities. Interoperability? Should be interesting to see how it unfolds.
The wording gives the impression of military force needed to patrol the area. A downtown "green zone"?k0co_5 said:DPD Chief just on Ch2 news explaining how they will staff up using forces from neighboring cities.
k0pwo said:I was told this weekend that Denver plans to have ESK on by the time the convention comes around.. Does anyone else have some insight on this?
I guess we will see if that happens...
In simple terms it modifies data "words" on an EDACS control channel by a set level. A "Key" set in the radio gives it the data offset info in order to properly decode the modified control channel data. Your scanner acts brain dead as it does not recognize the offset control channel data.cstockmyer said:Dumb question time, What is ESK?
scanlist said:In simple terms it modifies data "words" on an EDACS control channel by a set level. A "Key" set in the radio gives it the data offset info in order to properly decode the modified control channel data. Your scanner acts brain dead as it does not recognize the offset control channel data.
It's an electronic way to give the public the middle finger.
Thanks go out to the asshat's with ebay obtained radios that thought it would be kewl to progam up to transmit and start crap on several systems including Denver over the years.
Phil.
