DESIGNATOR DMR P25 FCC..
phantomcrow
Retired LE
Is there a way to pull up a frequency and look at the FCC records online to see if the entity is using digital, NEXDEN, P25 or only analog?
Most of the FCC searches allow you to do this, go to the frequency tab and click on the frequency number for more info.
do you know if it also says that they are using encryption?
Encryption and usage is not under FCC control as long as otherwise permitted, thus it is not listed in FCC records, same as the NAC/RAN/Color/PL codes.
phantomcrow
Retired LE
So they can use encryption without authorization? I thought there was some kind of permission required
Certain radio services allow it, others don't, if authorized in the licensed service it is automatically allowed should an entity choose to use it.
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
Yes. On an FCC ULS database search, click the Emissons tab and you'll see emissions designations listed on the column furthest to the right. See Radioreference wiki link here for a summary of emissions designations. Keep in mind that just because the emissions are listed on the license does NOT guarantee that the modes are indeed in use
This info is also available via the Radioreference license search...
phantomcrow
Retired LE
Can anyone explain this then?
hiegtx
Dallas, TX
In my experience, the FCC emission designation does not always guarantee that they are in fact using said emission.
Exactly.
The emission designaters that you see in the license only indicates what they are authorized to use, not what they are currently utilizing. You will find the occasional license that includes analog, P25 digital, DMR, and NXDN as well.
CanesFan95
Was Homeboys-Scanna
Banned
FL
If only the FCC would tell us the color codes, CTCSS, LCNs, RANs, etc. Now that would be some kinna dream.
