BCD325P2/BCD996P2: DGID help
jp106
California
Some I programmed conventional systems with quick keys, works fine.
I programmed trunk system: “TGID 001”with what I thought was a quick key 9 with group quick key 9.
can I scan it with my other systems one?
I think I’m missing something ,not able to manually go to it or scan it.!!! Where is it?
RoninJoliet
ILL
Did you choose the proper system, put in the freqys, set it up as SQK9 in the menu , many steps o take .....
tvengr
Well Known Member
Baltimore County, MD
Here is a PDF file that will answer all of your questions about using quick keys.
  • Uniden Scanner Quick Key Instructions..pdf
