Diamond SRH77CA on yaesu ft60 wont screw tight to body
KF0AWL
Hobo
Iowa
I bought the Diamond antenna to replace my stock rubber duck.
When I went to install it there is z large gap between the antenna base and HT body even with the rubber gasket packaged with the antenna.
My question is can I put a thicker rubber o ring to take up the space and not cause issues?
Or does the open space even effect the water resistance of the radio?
K4EET
Chaplain
Severn, Maryland, USA
Use a fatter O-Ring washer. Many hardware stores have a nice assortment. That is what I did. As far as the IP rating, I'm sure that Yaesu would say that anything but their OEM antenna would not be acceptable. 73, Dave K4EET
K9DWB
Greencastle, PA, USA
Agreed with Dave. I have the same Diamond antenna on top of my FT3D. One of my HT antennas came with a thin rubber washer that I stuck on first. I just leave it in place no matter what antenna goes on. I've got a SMAM to SMAF adapter I'm putting on when it arrives. I will do this so as to let the $5 adapter take the abuse and not the $350 radio SMA.
KF0AWL
Hobo
Iowa
Just got a email back from Diamond
They are sending me a ring to take up the space. See what they have and go from there.
K9DWB
I've only actively been in ham for 2 months. But I'm really liking Diamond antennas. Sounds like they have a good customer service as evidenced here. Hope the ring fixes the space issue.
K4EET
Chaplain
Was that Denise at Diamond that is sending you the spacer? She has helped me a couple of times. And yes, Diamond Antenna is a great company that stands behind their products.
KF0AWL
Hobo
Iowa
Im pretty sure thats who it was.
Not many companies have good customer service like that anymore!
W5GX
I cut a couple short lengths of heat shrink. I think they are the same diameter. I fit the antenna (Comet, in my case) and pushed one down till it stopped and shrank it, then did a second layer. I moved the outer tube just a hair lower so it has a good snug fit. It takes up most of the gap from the Comet antenna.
W5GX
The connectors themselves are standardized - thread pitch, thread diameter, pin diameter, etc.
The housings and various giblets around that connector? Not so much. :p
Unfortunately, there is a lot of freedom around the connector itself. Kind of rough for the end user.
