Digital reception question
gatorhater
Planet Earth
What kind of range of reception can be expected from the new GEWIN system that is being used? I'm trying to determine if I'm in a dead zone with the new GEWIN system.
Thanks.
b7spectra
EMS Dispatcher
Cobb County, GA
I've been able to pick up the Cobb GEWIZ over at PDK with no problems.
Guess if you were a GATOR LOVER it would pick up better! :)
AndrewC75
Kennesaw, GA
I get 2-3 bars on Cobb GEWIN in Alpharetta, and that's sitting under a Fulton County TRS / Metro GEWIN tower. I was actually able to (sort of) get Cobb GEWIN in White county, but that was at a very high elevation and I had to be on the right side of the mountain. To be fair, the design of the system is probably for something like 90-95% portable coverage within the county, so anything outside the county line is frosting on the cake.
