Of course modeling doesn't take into account real world affects, like me mounting a nice tubing folded dipole into an attic, as compared to someone mounting a skinny dipole outside up high etc.I'd go with the latter for sure.
What I see is that the wire-folded dipole is not all that bad when compared to the standard tubing dipole except at the bottom of the band. Of course the tubing dipole can actually be mounted outside like a real antenna should.
One interesting thing about the last one, the very wide folded-dipole made of tubing, is that I saw about a 2 to 3 db reduction of the main lobe on the side opposite the feedpoint when I did the directional plot. It makes me think that if one is using folded dipoles made with tubing, is to put the feedpoint facing the direction of interest, ie furthest from the tower or mount pointed towards the target just to be sure. (wire dipoles not affected by this shift much) And, this effect only started getting noticeable at center frequency (2db) and got worse up at 380 mhz (3db).
Again, this is all just modeling - the real world and my construction techniques can make a big difference - usually for the poorer.![]()
..I also have a military 225-400Mhz 4-bay collinear array but its sealed in a fiberglass radome and I don't know how its constructed. The company (Chu & Associates) has patents that could probably be looked up, otherwise its very difficult to phase antennas that cover a 2:1 frequency range.
prcguy
Makes me wonder just how/where the actual feedpoint of that folded dipole is - on the element that is clamped, or on the outside facing away from the mount?
.. If they have a matching section it is probably just a specific length of higher impedance coax.
...An isolated transformer might help. I've used the Radio Shack model 15-1140 and they are truly isolating transformers. They also have a 15-1230 that appears to be just a gold-plated version (ahem), which I haven't tested for isolation, but my guess is that it would be isolating too....
I still think for a single element antenna, a very fat coaxial dipole would be the best choice since it can be mounted with no mast interaction.
I built one out of discarded backyard umbrella mast, and NOW we are cooking! The elements slip over some pvc and the coax runs down inside. We could have gone with a side-feed, but with the wide spacing of the tubing as compared to the thinner coax run down the middle, it is a BIG improvement over the quickie "fold-the-coax-braid-back-down" type.
Thanks!
