jake22si
I am looking at buying or building a 200' dipole wire antenna. I would rather not have the feed line out in the open grass area. Is it ok to gently angle the feed line as it comes down to get it to the tree line, 10-20' in?
What type of feedline, coax or balanced? Its best to bring the feedline off at a right angle and it doesn't matter much if it goes sideways or down or a combination. Balanced line will have a problem laying on the ground getting to the radio.I am looking at buying or building a 200' dipole wire antenna. I would rather not have the feed line out in the open grass area. Is it ok to gently angle the feed line as it comes down to get it to the tree line, 10-20' in?
Im sorry, I am new and went to go buy the parts for this antenna, and looking at the kit I was going to buy to see how its made, it is ladder line feed G5rv style.The antenna you describe is not something you want to feed with coax unless it has a balun or transformer to help match it as many tuners will not be able to match it without a transformer and the performance will be all over the place from ok to not ok.
Do you have a tuner that will take ladder line directly? Instead of a random length non resonant 200ft dipole that will not have a good match on any band, why not look at the ZS6BKW, which is a 94ft center fed dipole using a critical length of 450 ohm ladder line then to coax and it provides a good match to 50 ohm coax on most bands 40-10m. You can use it on 80m with a tuner and the match is similar to a G5RV on 80m being about 5:1 to 7:1 VSWR, but it radiates well on 80m. The ZS6BKW will need a good ferrite 1:1 choke balun at the ladder line to coax junction.Im sorry, I am new and went to go buy the parts for this antenna, and looking at the kit I was going to buy to see how its made, it is ladder line feed G5rv style.
It is what ham radio outlet recommended for my receiver, or the best they had in stock of that style. When I looked in the package to see how it was made it looks like the ladder is converted to a pl259 fitting. I have a yaesu ftdx-10. I am planning on building my own antenna in spring, I have a vertical for now.Do you have a tuner that will take ladder line directly? Instead of a random length non resonant 200ft dipole that will not have a good match on any band, why not look at the ZS6BKW, which is a 94ft center fed dipole using a critical length of 450 ohm ladder line then to coax and it provides a good match to 50 ohm coax on most bands 40-10m. You can use it on 80m with a tuner and the match is similar to a G5RV on 80m being about 5:1 to 7:1 VSWR, but it radiates well on 80m. The ZS6BKW will need a good ferrite 1:1 choke balun at the ladder line to coax junction
