scanmanmi
I too have been researching this and have found lots of people suggest an FM trap. I just ordered one.
You can make ¼ wave stub filters so easily, maybe out of junk box stuff that they're great to do yourself. You cut them a bit long then gradually snip a bit off until you bring the frequency it cuts up. There's a nice simple calculator here.
Coaxial Stub Notch Filter Designer
Just remember they're quite wide, so if you want the aircraft band, a filter cut for 100Mz, nibbles into it, but cut it for 90MHz works pretty well.
Discones are intermod magnets. They are more efficient in the FM broadcast band than any other scanner antenna.
With all that said my go to antenna(s), which I'm using right now on my new Icom R-8600 is a a pair of Discones, one covers about 100 to 800Mhz and the other about 400 to 3,200MHz combined with a diplexer with a transition in the 600Mhz range. I rarely use a preamp and my coax is a combination of 1/2" Heliax and LMR400.
prcguy
What discone do you use for 100-800mHz?
Bob
" Kreco and Astron Wireless " now those are REAL discone antennas.
While scanner types from Comet, Diamond, Browning, Tram, and others are not designed, built, and tested, like the commercial ones and of course, they do not 'work' as well either.
