DMR 4 Slot - had anyone else seen rumors this is coming soon ?
KC2OVX
I saw this is in the pipeline at Motorola. Has anyone else seen this, and is there anything official from Motorola about it ?
Or anything about it on the web ?
PACNWDude
Is this 6.25kHz that you are talking about.....like two-slot TDMA takes 25kHz, but effectively in two 12.5kHz pieces of spectrum? If that is the case, there has been talk for a while, and it will most likely get pushed out like 25 to 12.5 kHz channel spacing was delayed several times. Narrow-banding eventually took place at the beginning of 2013. Much later than it was originally proposed and talked about.
KK6ZTE
California
Two slot TDMA uses one 12.5kHz channel and makes two 6.25e voice paths, unless I'm misunderstanding you.
GTR8000
NY/NJ Database Guy
BEE00
2 slot TDMA is a 12.5 kHz wide channel, not 25 kHz. The time slots alternate, they don't sit side by side. 4 slot TDMA like OpenSky or TETRA uses a 25 kHz channel.
PACNWDude
Wow, margarita day hit me hard....yes 12.5 kHz wide, not 25 kHz wide for 2 slot TDMA.
kruser
West St Louis County, MO
What's the point, I thought the whole narrowbanding thing was to get rid of 25 kHz wide channels?
I guess if you need 4 slots then a 25kHz frequency is needed but you would not be able to locate another narrowband user next to any of these systems. I guess they must coordinate that also when working around an OpenSky or TETRA system though.
There are sections of spectrum that did not narrow band. 800MHz still allows 25KHz channels, but I cannot imagine Motorola sales would allow/do anything to jeopardize any of their P25 offerings.
I wonder if this is directed at other countries?
com501
4 slot TDMA has licensing issues in the USA. There are a few experimental licensing issued for testing, but 4-slot TDMA ie TETRA is an issue in the USA vs EU.
GTR8000
NY/NJ Database Guy
BEE00
NYC Transit and NJ Transit are fully licensed to operate 4-slot TETRA in the 700 and 800 MHz bands, respectively. Nothing experimental about it, no waivers required, they have been issued full 10 year SY and YE licenses with 22K emissions. The NJ Transmit system operates outside of the NPSPAC 851-854 spectrum, per the FCC order in 2016.
com501
Where narrowbanding is required, as below 800, it isn't going to happen any time soon. In my part of the country, there is scant 800 usable because of terrain.
Project25_MASTR
Millennial Graying OBT Guy
Texas
When someone says 4 slot TRBO system...I immediately think of how Capacity Plus counts channels. Repeater 1, TS 1, TS 2. Repeater 2, TS 3, TS 4. Repeater 3, TS 5, TS 6...
So technically Motorola already has it...a 4 slot system is just a two channel Capacity Plus system. Want to put it in 25 kHz of spectrum? Let's pull a Kenwood (with NXDN dual 6.25 kHz channels in a common 12.5 kHz) and say we can do that...just need two Repeaters and a hybrid combiner.
