DMR Hotspot
n7gta
I have an Anytone 878UV and an Anytone 878UVII and 2 Btech 6X2's. They are all programmed the same, sa well as I can tell, but only the 878UV works with the pi-star hotspot. all are able to receive the hotspot though. They are all able talk to each other in simplex. I have run out of ideas. Help?
YL3IM
KO26BX
Double-check the codeplug settings and make sure they're indeed programmed the same way. Are Btech radios assigned the same DMR ID? If not, set the hotspot to Public instead of Private.
dcr_inc
Feed Provider *York Pa.*
Delta, Pa
The DMR ID can not be exactly the same.. Add a "17" to one of them and see if tat clears it up
KD8DVR
Columbus, Ohio
The DMR ID can most certainly be the same. Each radio MUST have the same DMR ID. This DMR ID MUST match the ID on the hotspot.
You only add the two digits at the end if you are using multiple hotspots on the same DMR network.
dcr_inc
Delta, Pa
"The DMR ID can not be exactly the same.. Add a "17" to one of them and see if tat clears it up"
OK.. So adding 2 digits makes it a DIFFERENT ID..
The server can not send data to multiple units with the same ID at the same IP address..
dcr_inc
Delta, Pa
exactlly the same digits in each DMR ID, No extension digits, all on at the same time at the same location..OK.. I concede
dickie757
Wired
Out of range
Make sure transmit offset/repeater mode set to 0, off.
You say they can talk to each other in simplex, can each hear the transmissions meant for the hotspot?
