DMR programing
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Nope,. doesn't look like it...
Mike
bradam2001
Gaithersburg, Md
I got mine the other day from Unication in Texas and ordered the DMR before I got it. Still haven't had any luck with picking up DMR.
This is my 2nd radio, first is the G5 with VHF with out DMR
blackbelter
Is it possible to program this on a G5 with DMR 450-520 mhz. Thanks for any help
460.65000465.65000WPTR711RMCC 14
TG *
SL *
IAD JtBl .65JetBlueDMRBusiness
[/QUOTE]
Yes, with a Unication DMR enabled G5 ( UHF D) you can program the pager with a conventional DMR frequency. I monitor a single DMR system with my DMR enabled G5. You need to select DMR with the proper CC and TG.
blackbelter
You can, however if you have the TG and the CC place them in the appropriate tabs. Follow the PPS directives and when selecting a zone make certain that you select the DMR from the drop down menu as your system to monitor. There are a number of good tutorials on the U tube.
N6ML
Is there a wild card for the TG on DMR ?
There is none that is officially documented (at least that I've seen). I can say that when I experimented with the local ham DMR repeater, I was able to receive traffic (on several TGs) when configured with a TGID of FFFCDF, which was a total guess at a wildcard. If you search this forum for "DMR wildcard", you should find some past discussions about this, including people telling me why I'm wrong (even though I never said that this is an official wildcard - only that it worked for me - I even posted a YouTube video as proof!)
pro106import
Milford, Ct. perched high above Long Island Sound
Just a note. I was having the same problem not recieving anything. Make sure the Repeater mode (Digital) box is checked (Enable). See photo
