I am currently using DMR. The learning curve is still going up. I like DMR, but I also want to learn a bit more about the other modes. This is what I am trying to determine right now:
-Yaesu System Fusion: My understanding is that although the programming is similar to APCO P-25, you don't need a NAC code. I also am aware that repeaters are generally capable of mixed-mode meaning they will pass analog and/or YSF modulation. It looks like the YSF repeaters I have seen usually need a PL/DPL for the analog side. Am I correct in assuming that all you need to access the YSF side is the proper frequencies programmed in and transmit in the YSF mode?
With regards to networking and YSF rooms. If a YSF repeater is connected to a "room", I assume everybody tuned to that YSF frequency hears activity on that "room", correct? correct? I know with DMR you can select a specific talkgroup and you won't hear other activity on the repeater, so I suspect YSF is very different in this regard.
I have a digital hot-spot and I suspect that a radio, through a hot-spot that is YSF capable, can select whatever "room" you want, correct? I also suspect that YSF repeaters that are linked to that "room" will hear the traffic, correct? Are most YSF repeaters connected to a single "room" or are some connected to more than one "room" at a time?
Is there any way to monitor a particular YSF repeater and ONLY here traffic from a specific room or is it an all or nothing situation with YSF?
I have also heard that a number of places got the YSF repeaters because of the attractive pricing, but are actually used mainly in the analog mode? Is that an accurate statement or does it vary from place to place?
-Icom D-Star: I gather that your call sign needs to be registered and I have made application for that. It looks like programming for Icom D-Star is much different than DMR or YSF.
With regards to D-Star and reflectors, I assume that if the repeater you are tuned to is connected to specific reflector, all local users, tuned to that D-Star repeater, hear any traffic on that reflector over that repeater. Do some D-Star repeaters connect to more than one reflector at a time? Are there some D-Star repeaters that are completely stand alone and aren't connected to any other repeaters at all?
I have heard and read that the audio quality of D-Star is generally inferior to other digital modes. Is that true or is newer equipment sounding more natural?
What about using a hot-spot on D-Star? I assume that you select reflectors using those and it doesn't matter what repeaters are carrying that particular reflector?
Are any D-Star repeaters also analog or are they excursively D-Star?
-APCO P-25: I had some XTS5000s and an APX7000 in the past. The P25 repeater I used wasn't linked to anything. Similar to the above questions, are their many linked amateur P25 repeaters now? Is hot-spot use to access P25 common? I have never heard about rooms or reflectors on P25, but I have heard about talkgroups. Do most P25 amateur repeaters make use of multiple talkgroups? I assume to Motorola Quantar is the common P25 repeater. Are most configured to work mixed-mode, both analog and P25?
-NXDN: I have used NXDN for work, but never on amateur radio. Again, are there rooms, reflector or talkgroups used on NXDN? If a particular talkgroup is in use, and carried on a NXDN repeater, I assume that repeater can't be used for anything else at that moment, since there aren't dual time slots. I assume that NXDN repeaters carry traffic from multiple talkgroups. I also assume that you can program a NXDN radio and monitor for just a single, specific talkgroup. What about hot-spot use? I assume that you use a NXDN radio, connect to the hot-spot and then select a specific talk-group?
