That’s the problem I have. I’m currently using two scanners and 2 antennas. One has an attenuator to weaken the signal on VHF to stop overload. The other pulls in full strength UHF as that’s not impacted by the overloading signal.I think you're looking for a frequency filter. Attenuators help lower the strength of the signals so the scanner doesn't overload/decode better.
Won’t a band pass kill off the section of the signal completely? I still need it coming into the scanner, just attenuated a bit, with the rest untouched.Yes, they exist, not sure about variable. Band-pass filter
It does the opposite, only allows the band (of interest) through, attenuates the rest. You can run an attenuator inline with a band bass filter if you need to.Won’t a band pass kill off the section of the signal completely? I still need it coming into the scanner, just attenuated a bit, with the rest untouched.
YesAre you near powerful transmitters?
Can’t be notched for a number of reasons. The interference is across the band and also a notch filter isn’t precise enough to not kill off the channels next to the interference that I would want to listen to.You don't want an attenuator, you want a bandstop/notch reject filter tuned to the strong signal(s) causing the problem. An attenuator will reduce all signals passing through it, not just the problem signal(s).
Scottish VOLMET broadcast on what appears to be multiple frequencies from the mast a few fields away. It broadcasts to all of Scotland.What is the source of the interference? If it's across an entire band that's a serious issue, not just for you, but for everyone using VHF freqs in your area.
I see a VOLMET broadcast from Prestwick Airport on 125.720 MHz. Is this the source?Scottish VOLMET broadcast on what appears to be multiple frequencies from the mast a few fields away. It broadcasts to all of Scotland.
Are you using one scanner for multiple service monitoring?
What about antennas? - single-band, multi-band, broadband (discone)?
I'd take a look at Comet or Diamond duplexers/triplexers in the frequency ranges you wish to monitor. Pick one which passes 136MHz and above, or (as I did) use a combination of various models to feed banks of VHF low-band, VHF high-band, UHF and 800MHz-up receivers. A couple of feed paths off the distribution manifold are wide-open (covering all frequencies) so I can drive my wider-coverage receivers with them.
