jonwienke
More Info Coming Soon!
I use a stub filter tuned to block cellular in the 600/700MHz range. I used a nano VNA to tune it to minimize attenuation of UHF T-band and the upper 700/800MHz band. @majoco is correct that a stub filter will also block odd multiples of the base frequency, so blocking 125MHz will also block 375MHz and so on. It may be desirable to use a diplexer to separate VHF from UHF, and put the filter on the VHF side of the output to keep it from notching UHF airband as well.
