DP vs Xpr MOTOTRBO™ radios.
PT333
Is there any difference between the DP4800 vs xpr 7550. Is the software interchangeable?
PT333
Ok thanks, would there be any issue using 5-6 DP radios in america with XPR radios in the system if i use the two different CPS softwares.
Floridarailfanning
Tennessee
You cannot use DP/DM radios in North America. They are not FCC or Industry Canada approved and are configured for the EU band Plan. Plus Motorola will not sell you the EU version of CPS.
PT333
Would it really matter as they are essentially the same radio. I already have legal cps and a few radios
alcahuete
Southern California
That's for you and the FCC to decide. Is anything going to happen to you for using them? Probably not, but the fines are quite hefty if something should. Only you can decide if it's worth the risk.
