Actually Dressler antennas have had a terrific reputation in the HF world, but I haven't heard a thing about how well they work above that.
Generally speaking, N Jay is right - having an amp in an urban setting is asking for problems. Put up a good antenna - and the right coax - first, then add a preamp later.
I'm going to bet that you are in a restricted environment - one where you can't have antennas outdoors. There's a Larsen antenna that covers 150/400 and 800, and works quite well from all accounts. Put that on a mag mount on a metallic surface, preferably near a window and you're probably as good to go as you will get.
If you have an attic you can use, there are many other possibilities....
73s Mike
