DSD+ FL to Rdio-scanner how to properly import talkgroups from RR
nexusjuan
I've got Rdio-Scanner setup watching DSDplus FL record folder. I've imported the talkgroup file from RR for the site that I am listening too. I set the dirwatch to the system that the imported talkgroups go into. However it does not recognize the talkgroups from the meta information and doesn't play them through the client. It just says unknown talkgroup and does not play the audio. If I set it to autopopulate it will make a new system called system 464 with the talkgroup number but not the correct label information. It will however play the audio through the client but the talkgroups aren't labelled correctly. What am I doing wrong?
nexusjuan
Check that all your system info is correct. I had mine working slightly a while back.
I finally just let it auto populate then input the correct talkgroup information. This is probably better as it lets me discover new talkgroups as they're added. I found a talkgroup that wasn't in my database using this method this morning, then managed to locate it in the feed and identify it from the audio as someone from an outside agency using the line. I really like the interface of rdio-scanner. Now I'm trying to figure out how to get it to connect when I'm off of my home network.
dave3825
Suffolk County NY
I'm not that up and up on this program but I had uploaded the csv for my system and for some reason it was not working properly, but the auto populate seems to work fine. Only downside to that is you can't set non interest tg's to off from the start.
I have Sdrtrunk and Unitrunker both feeding to Trunking Recorder. So when playing with the dirwatch directory, I had it set to Sdrtrunk record folder. But trunking recorder seems to move those files into its own directory so after I set dirwatch path to that, it started working. I only wanted rdio scanner to handle one system but its doing all systems sdrtrunk and Unitrunker are sending to trunking recorder. So if I just create those unwanted systems, I should be able to toggle them off.
nexusjuan
I think I'm happy with how I've got it setup now. I'd really like to be able to stream it from anywhere and share the link but it only works when I'm connected to the same router that its on.
