Spartanman
- Joined
- Feb 20, 2023
- Messages
- 53
Oh thanks! And that data can be decode in some way?It shows a Conventional DMR Repeater on 164.3875, but its only transmitting data and no voice. So there are no voice frames for DSD+ to decode.
Great. Thanks!It's simply beacon data, and DSD+ is already decoding the most useful data. So you're not missing out on anything !
nope. Spain@Spartanman where are you located? Are you in the US?
Hi guys. Im trying to decode some DMR but i dont gent nothing. What can be?
View attachment 141114View attachment 141115
I dont hear nothing with that configuration. I somethimes receive speech but is not clear.Yeah, under the audio tab. Filter Audio should be unchecked (looks like you have it unchecked)
You should:
a. set mode to NFM (not WFM)
b. change the Bandwidth from 32000 to 8000
If that doesn't work, you have other issues -- probably related to that plugin configuration, which is not standard.
ouh, ill search for that freqThat's only showing data "BS DATA". But there is more than one frequency on that Cap+ system. Rest channel is 3, which indicates there are (at least) two frequencies on that Cap+ site. The audio is likely occurring on another frequency.
If you DO hear audio but can't make sense of it, it's because Basic Privacy (BP) encryption is in use.
Thanks for the help! Ill try finding itIt's because the transmissions are encrypted. BP (basic privacy) and EP (enhanced privacy?) indicate encryption.
You can/should. But it may not be worth your time IF ALL traffic is encrypted.
Ok, thanks!!When it is active it's also going to show Cap+ DCC:9
IM LISTENING SOMETHING!When it is active it's also going to show Cap+ DCC:9
