WACN: BEE00
System: 14C
RFSS: 5
Site: 23 (NAC: 140)
has the bandplan:
Bandplan #0: Base=851.006250 Offset=-45 Spacing=6.25 BW=12.5
Bandplan #1: Base=762.006250 Offset=+30 Spacing=6.25 BW=12.5
Bandplan #2: Base=380.000000 Offset=+10 Spacing=6.25 BW=12.5
Bandplan #3: Base=406.000000 Offset=+9 Spacing=6.25 BW=12.5
Bandplan #4: Base=380.000000 Offset=+10 Spacing=6.25 BW=12.5 Slots=2
Bandplan #5: Base=406.000000 Offset=+9 Spacing=6.25 BW=12.5 Slots=2
Bandplan #6: Base=136.000000 Offset=-8.6 Spacing=6.25 BW=12.5 Slots=2
Bandplan #7: Base=380.000000 Offset=+10 Spacing=12.5 BW=12.5
Bandplan #8: Base=136.000000 Offset=-8.6 Spacing=12.5 BW=12.5
Bandplan #9: Base=136.000000 Offset=+4.6 Spacing=12.5 BW=12.5
Bandplan #10: Base=380.000000 Offset=+9 Spacing=12.5 BW=12.5
Starting with an empty DSDPlus.P25data file and then listening to the CC 385.9125 yields these (correct) entries in the file:
Site: 5.23 NAC=140
Channel 2-856: 385.350000 SCC
Channel 2-946: 385.912500 CC
WACN: BEE00
System: 14C
RFSS: 5
Site: 6 (NAC: 14C)
(another site of the same system) has the different bandplan (with 12.5 kHz spacing for channel prefix 2):
Bandplan #2: Base=380.000000 Offset=+10 Spacing=12.5 BW=12.5
Bandplan #3: Base=380.000000 Offset=+10 Spacing=6.25 BW=12.5 Slots=2
Starting with an empty DSDPlus.P25data file and then listening to the CC 386.0625 yields these (correct) entries in the file:
Site: 5.6 NAC=14C
Channel 2-485: 386.062500 CC
Channel 2-497: 386.212500 SCC
Channel 2-667: 388.337500 SCC
However, if you start with an empty DSDPlus.P25data file, then first listen to site BEE000.14C-5.23, it writes the first bandplan table to the file to be used for all of system BEE00-14C, with channel prefix #2 using 6.25 kHz spacing. If you then, without restarting DSDPlus, listen to site BEE000.14C-5.6 CC (on 386.062500), it incorrectly assumes the same 6.25 kHz channel numbers and displays the following in the Channel Activity window:
Ch Freq Target
2-485 383.03125 CC
2-497 383.10625 scc
2-667 384.16875 scc
(displaying the wrong frequencies for site 6).
Further, it does the opposite thing when writing the DSDPlus.P25data file, overwriting and using bandplan #2 with that received from site 6 (with 12.5 kHz spacing) and recalculating site 23's frequencies incorrectly (but site 6's correctly):
Network: BEE00.14C
Site: 5.6 NAC=14C
Channel 2-703: 388.787500 VOICE
Site: 5.23 NAC=140
Channel 2-856: 390.700000 SCC
Channel 2-946: 391.825000 CC
(I've eliminated unrelated neighbor information. Also note that it over-wrote bandplan prefix #3 with the (380 MHz) range from site 6 (the one from site 23 is for 406 MHz).)
If you restart after it writes the file, the Channel Activity window then does the same thing as the file, displaying the wrong frequencies for site 23 instead of site 6.
In summary, the problem appears to be that DSDPlus assumes the same bandplan table for all sites in a system (unique key of WACN.System) instead of allowing separate bandplan tables for each site (unique key of WACN.System.RFSS.Site), and handles conflicts between information sent by the sites differently in the Channel Activity window than it does in the DSDPlus.P25data file.
(I have raw audio files and DSDPlus.P25data files of these tests if necessary)
P.S.: I don't know how old this problem is. I haven't used DSDPlus in a long time, and don't know if the issue existed back then.
System: 14C
RFSS: 5
Site: 23 (NAC: 140)
has the bandplan:
Site: 5.23 NAC=140
WACN: BEE00
System: 14C
RFSS: 5
Site: 6 (NAC: 14C)
Site: 5.6 NAC=14C
Ch Freq Target
2-485 383.03125 CC
2-497 383.10625 scc
2-667 384.16875 scc
Network: BEE00.14C
Site: 5.6 NAC=14C
Site: 5.23 NAC=140
