Mootly
I am brand new to DSDPlus FL and I am very impressed with the improvements over the public release. In particular, the ability to start FMP24 with a USB device serial number eliminates the problem of trying to determine which radio is in use. Keeping in mind that I have no idea how difficult it is to make changes to the software, here are just a few questions which might lead to feature requests:
1. Is there a way to run FMP24 with a lower sample rate and smaller spectrum window width? For some of my scanning applications I do not need the higher rate/width.
1a. Alternatively, can FMP be modified to allow assigning a radio by serial number? In the larger scheme of things, can FMP be modified to include the same command set as FMP24?
2. Can FMP24 be modified so that Esc does not exit the program? When trying to manually pause a scan by hitting Esc, it is too easy to hit it twice and cause the program to terminate.
2a. Alternatively, can FMP24 be modified to use a different key, other than Esc, to exit scan mode
I really appreciate the effort that has gone into DSDPlus, keep up the good work.
