Dumb antenna/scanner question
cpsTN
Smyrna, Tennessee
My scanner (PRO-164), like many others, receives the 40 CB channels. Although the interstate (I-24) is only about a mile from my home and I can hear the traffic FROM my home, I can't seem to pick up much at all. I am thinking of buying a small CB antenna and using it with the scanner when I am scanning these freqs. Could this be the scanner, using a rubber duck antenna, or is there a decent chance there is not much in my area to hear? I am listening in Rutherford County, Tennessee, just outside the town of Smyrna, about 10 miles from the outskirts of Nashville.
gewecke
Banned
Illinois
Due to better choices for two way radios,it could be that cb traffic in your area is lighter than others.
It's probably not any fault of yours. :)
n9zas
gmclam
Fair Oaks, CA
Antenna is everything. CB, 11 meters, is a fairly long antenna. The stock rubber duck antenna is a compromise across all the frequencies the scanner can receive.
One of the agencies I focus on listening to is CHP, which are on low band VHF. There's a HUGE difference in reception between the stock rubber antenna and an external antenna designed for that band.
canav844
A proper antenna will make all the difference. Holds true to just about anything radio that I've experienced. The Scanner won't be great and I'd rather tie up a $30 CB from walmart or the local truck stop to listen to CB regularly, but once in a while I throw the scanner on the CB bands. CH19 and CH6 is where I've found activity on the band 99% of it's on 19 though.
CalebATC
Blairsville, Georgia
I remember I was on the way to NC one time and their was a traffic jam, the only truckers I heard were the ones about right next to me. If you don't have to turn the squelch down from the transition to a UHF freq, its the antenna. In other words, 11 meters has a lot more noise than about 80 MHz up.
Time to string up some wire for a 11 meter dipole. Or, just get a CB antenna, which will cost you a lot more.
CalebATC
I remember doing that many years ago. I had forgotten about that solution - and if it doesnt work, what have a lost, right? Thank You all.
You haven't lost anything except for a couple of inches of wire, a couple inches of coax, and about 3" of pipe- just make sure you hang it vertically.
just do 468/center frequency
Sorry if it is a little messy, but if your not familiar with a dipole, theirs some guidance. Just Google dipole for CB, I'm sure you will get more than needed.
mdickerson17
Las Vegas, NV
That was the same for me stuck in a traffic jam here in vegas, I could literally see the truckers talking on the cb but couldn't hear anything till I was right next to them. The rubber duck just doesn't like the low freq's! Funny I came across this thread though, my uncle just gave me his old cb a couple days ago......LOL
Zagadka
Central NC, USA
I might suggest that you find a friend with a CB to take you out on "the boulevard" and see if there's much if any traffic to actually hear before you spend any effort or money. Like you, I have a 164 and I put a RS scanner antenna on the trunk and scanned the CB band on a trip of 120 miles on I-40. I heard almost nothing. Then I dug out some old CB handhelds and hooked them up with a trunk mount antenna and listened on a 5 hour trip to DC on I-95 - again, almost nothing until we got within 5 miles or so of a truck stop or a traffic jam.
My recollecion from back in the day is that CB was pretty busy but such isn't necessarily the case any more. YMMV
