Duplicate Talkgroups On Radio Reference
ThePolishDude
N.E. Ohio
1.) Talkgroup In Ohio MARCS - 59863 - ODH Mutual Aid - County Health and Southwest Region Calling. It is under Clermont Countu and Ohio Department of Health
2. Talkgroup 56831is listed as Strongsville Fireground 11 and Fireground 11 for the Southwest Emergency Dispatch Center. This talkgroup number can ebe found under the Greater Cleveland Radio Communications Network.
Jphila20
Retired LE. Honor our Fallen.
Southern Lorain County, Ohio
I monitor the Cuyahoga County Site 002-001 and this TG does not show up when searching with Unitrunker.
"56831is listed as Strongsville Fireground 11"
KB8VJU
Cleveland, Ohio
Strongsville can use this talk group, but it’s part of the SWEDC fire grounds. It’s not specifically only for Strongsville.
I don't see it, looking at the database for Ohio MARCS and looking at all TGs both those are only showing once. Are you sure you aren't mixing systems?
59520 e880 D LHD SW Southwest Region Calling
59863 e9d7 D XCLERMONT ODH Mutual Aid - County Health Dept
I think you are confusing Strongsville Fireground 11 on the GCRCN (which is actually 56381 not 56831)
dave3825
Suffolk County NY
The only duplicate on OHIO Marcs is tg 59012. It's listed in these two departments.
Clermont County Common
Clermont County Local Government/Public Works
wd8chl
I'd bet both are true in this case. It's common for two different agencies to have the same talkgroup/channel programmed, but call it something else. Besides, isn't these names ones that users here have come up with to describe them, not what MARCS (or whoever) actually calls them?
I'm sure it's a public works channel, and other dept's have it in their radios as well, and use it for other things once in a while.
belvdr
No longer interested in living
Yes, it's user submitted data.
It looks like it's mostly just the category. Is it "Common" or "Local Government"? Many counties in MARCS have their EMA in the "Common" category, so it makes sense to have it there for Clermont.
wa8pyr
Staff member
Lead Database Admin
Ohio
Fixed.
Just a reminder to all, if you see duplicates like this, please submit so it can be corrected.
