Durham Regional Police
Rasa
Someone told me that its not possible to hear durham police because they keep on changing their algorithm or soemthing like that.so there is no scanner out yet that can pick it up..so what system are they usin?are they encrypted or something? wats with fire and ems in durham?
also how is it possible to pick up walkie talkie frequencies e.g costco etc..i went out into the costco parkin lot and tried close call on my 396..i didnt really pick up anything.do i have to give CC some time or what?thanks
IdleMonitor
The Ottawa Valley - Eastern Ontario
I'm pretty sure they're on IDen so it's un-monitorable. I'm sure others can chime in with a better explanation.
The rest of Durham region can be found here http://www.radioreference.com/apps/db/?ctid=4288
mciupa
Canadian DB Admin
Moderator
I'm here a lot
There is also this simplex freq. which means you would have to be within range of the transmitting handheld.
* Use discretion if you happen to hear something close by*
139.680 (146.2 PL) DRPS Police - Tactical
N
nec208
Guest
You have to have a scanner that can pick up ident and I don't know of any scanner that can pick it up.
Does ident use cell phone frequencies or just other truck radio system using digital modulation other than P25 like province radio system?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Ident is short for Indentification and is a department usually associated with a police department.
IDEN is what Durham Regional PS uses and it's what the Telus MIKE system is.
No, it' uses the regular SMR frequencies.
You mean like Freightliner or Mack?
N
nec208
Guest
Do you have the frequencies?
No I mean is it just like other modulation like province or P25? And are there on a trunk radio system or not?
But is Telus MIKE system trunk radio system or cell system out side the cell phone band?
rhutch
Ontario
nec208 said:
Do you have the frequencies??
They're SMR frequecies all the stuff is digital and unmonitorable by normal hobbiest monitoring equipment.
nec208 said:
No I mean is it just like other modulation like province or P25? And are there on a trunk radio system or not??
province??? Like Ontario, or do you mean Provoice? The answer is its Iden.
Like he said already its SMR which are cell phone frequencies, It's not a trunked system.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
No, I didn't say that.
SMR (Specialized Mobile Radio or something like that) is roughly 851-869Mhz.
Cellular is 869-894Mhz.
N
nec208
Guest
Thats see APCO-25, VSELP, AEGIS, and Pro-Voice all different digital Modulation ..
N
nec208
Guest
Is Iden digital modulation ? Are they on a trunk radio system or not?
