Ef johnson 51sl es 700/800 mhz... can i change it to uhf vhf?
Tttom
Can I flash this or what can I do to be able to program uhf/vhf frequencies to be able to use this as a police scanner. I tried once using pc configure 2.18.6 and the radio version is 6.18.0. It recognizes the codes but comes back "bad band". Should I return this because it's not capable to recognize those frequencies or what can I do
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Not possible, the hardware in the radio will not allow it. Pack it up and get a refund if you can.
