Hi,
I have a couple of question about on inverted V dipole setup.
I have an inverted V up in a tall tree at about 1 wavelength high, at that height it has some directional properties, which is fine, but I wanted to put up a second dipole perpendilcaur to the first one and then hook both dipoles up to an antenna switch so I can switch between them for different directions.
My questions are,
a) Will the dipoles react or interfere with each other (ie affect the radition pattern of each other) ? I plan to have each on a seperate branch a few meters apart and at slightly different hieghts, plus at 90deg to each other ?
b) Will the anetnna switch effect the radition patter, since hooking both antennas to the switch will result in a common earth so that antenna are essentially partially connected through the elements connected to the outer shield of the coax ?
thanks.
Steve
My questions are,
thanks.
Steve
