if I may add my 2cents...
I cant comment on the 2402, as I dont have one, but I do own/use a 2802. Many of times i have used it without having all ports terminated to a radio and just having an open coax just sitting there. I dont have any serious test equipment to make or see any +/-, but I can tell you what my ears tell me, and that I have heard no audible difference in any signal that I want to hear - which includes frequencies from 42Mhz up to 860Mhz+ and all frequencies inbetween.
I did have intermod problems at one time , but was using radios shack brand RG6 - all of it dissappeared when I switched everything to RG6U/Q.
I cant remember where I saw it, but there was a suggestion on a manufacturers website that says when not using all ports, to terminate the unused ports(no reason given). Ive never terminated any of my unused ports as ive never seen/heard any downside to it, other than it may lead to unwanted signals or noise to get to your radios(which I have NOT experienced)
My inputs were never amplified
I dont use it on my main setup now, but I do use it in the garage on 2-3 radios at a time when im in there, listening to just as wide a frequency range as I do in my main shack - with none of the other ports terminated to anything and still getting great results.
Reading what benbenrf posted makes alot of sense to a layman like myself, and would make me want to research further. But not having such insight in the past and having used it already, im not dissapointed.
I believe the port to port isolation is 25dB
Info:
http://www.electroline.com/en/products/drop_amplifiers/eda_ug/950-0013_EDA-UG_fact_sheet.pdf
