Entry Leader to Entry Team..Pinellas
kayleesdad
Picked up this interesting one this afternoon around lunch time and jotted down some notes before getting back to the computer. It was on 37568. I was wondering if it is a patch to a conventional channel or something, a bleed-over from another county or something else.
Comms went something like this:
Entry Leader to Entry Team you have been in for ….5 minutes….10 minutes….15 minutes…
Entry Leader to Safety ....one coming out…
Entry Leader to Entry Team….a bottle on the Bravo side...
Entry Team to Entry Leader…we are exiting….
Entry Leader to Entry Team…..radio check.
Entry Leader go ahead Safety…
The only thing I could find on Pinellas 911 active calls was a “Hazmat Upgrade” on Keller CI (east of Tarpon Springs) with E58, S57, D57, H66, H29, H33, H38, HM100, and LK 400. Can’t tell if it properly relates to this call, although it would appear that it could relate to it.
Is it possibly an extension of FIRE/EMS LP-# series in the Pinellas Motorola system, and if so what would it be called? LP-L?? Probably not “Hazmat”, though.
37408 LP-G
37440 LP-H
37472 LP-I
37504 LP-J
37536 K -??
37568 L -??
KiloPapa
37568 92c A HAZMAT Hazardous Materials Response Team Fire-Tac
37664 932 A EC-SAR Eckerd College Marine Search And Rescue (Used when marine channel is busy) Fire-Tac
Please save us, these talk groups do not exist, I look at a FD county radio everyday and no not a personal programmed to the county system. Please get things right before you post Pinellas grps. Most of it is correct and i think it should be kept that way.
So it does exist.
kayleesdad
Is there just one Hazmat Ops channel, or is there another one directly below it or above it (37600)?
Also, would you know the name for 38656 that falls between
38624 St pete low priority F
38656 ???
38688 St. pete low priority G
Thanks,
Bolt21
Spark Chariot Driver
Punta Piñal
dad, have you heard activity on 38656? In keeping with the pattern, it's as if 38656 should be "G" and 38688 should be "H."
kayleesdad
Recently, Unitrunker had a over a hundred hits on 38656. I didn't take any specific notes on it and had already locked it out of my non-Fire/Med search lists. Haven't heard it on my fire med search lists recently, though. if the 32 spacing is consistent, it might be G. maybe someone on the inside can help us out with this one.
Clearwater
38656 ???
Thanks,
Just one buddy. Those St.Pete LP are not in use.
