XTL/XTS5000 Error Code 1012
Tedh0388
Warminster
Good morning All,
I am not too new to Motorla programming, but I have an issue that I cannot resolve. I have a XTS500 model 3UHF and a XTS5000R VHF. The UHF is fine, all programmed. The XTS 5000R VHF ....well that's another story. It reads fine. When I go to upload even the factory plug, I get an error code:
The Feature Set does not match error context 2,a status c0001012.
It is the same radio with the same serial number. I am baffled. Did I click on something somewhere, what am I doing wrong? CPS version R20.01.00. I even tried another computer, tried drag and dropping it. Nothing is working.
Please help! Ty
UAT_978
The flashcode (feature set) is different between your codeplug and the radio. You will need to do the drag/drop method:
Open 2 copies of CPS side by side
In one of them, read the radio and save the codeplug something like "ORIG.cpg"
in the other, open the source codeplug
Once both are open, grab the top "node" of the codeplug and drag it over to the top node of the radio you read and let go of the mouse.
CPS will transfer the data into the radios codeplug.
Save this codeplug with a different name
write the radio.
Should be good to go.
