ProScan: Error codes while using Proscan
aprswatcher
Lewistown, Montana
A friend just received an SDS-150 scanner. I created an sd card from my SDS-100 files. He inserted the sd card and booted up the SDS-150.
Everything has worked good. He has downloaded Proscan and has used some functions on it.
He has tried to read the sd card from the SDS-150 in order to add to the favorites and got error codes, tried a different sd card and same results.
He can use Sentinel and it works OK.
Ideas?
I have used Proscan for numerous years and have never received any error codes!
The pictures are too large to post.
this is what it reads:
Profile Editor
Object reference not set to an instance of an object
C:\users\mdtcom\documents\uniden\BCDx36HP\profile\old
73, Rex
ProScan
Software Provider
Ontario, Calif.
Ideas?
Profile Editor
73, Rex
If there's an error code, why doesn't your friend send me a Bug Report so I can send him test files until fixed.
Also you didn't state the version #. It's most difficult troubleshooting in line like this.
Bug Reporting and Suggestions
