error launching Vertex Standard Clone Editor
riccom
K A N S A S C I T Y
i have re installed my windows 10 laptop, and when i launch this program, i am getting the error uploaded below.
tried compatibility and as running as admin.
and tried in 32 bit of 10 (currently on) and nothing.
downloaded from the motorola site itself, not bootlegged.
is there something i am missing here???
radiotweester
Oregon
No solution, except maybe an older Windows program or try running a virtual machine of such. I found a post from 2019 with your same problem "Vertex Standard Clone Editor Problem" and it went unresolved. I know 10 is NOT friendly when I've tried to install and use different Vertex CE-## software. It might be coming another issue like the early 2000s where there's an old DOS 386 in the corner for programming the still fully working, but EOL radios. Good luck!
lookforthe1
have you tried compatibility mode?
from what i recall if you set it to xp sp3 it should work
doughboy5100
West Central, WISCONSIN
Try running as administrator. It works for me on my Windows 10 Machine.
From the task bar Right click on Clone Editor, More, then run as administrator.
