Alright Gordon, I tested Scanner Radio out at work some more and it appears the issue is something with either the app or radioreference. The feeds will cut out and keep reconnecting in cycles every 5-10 minutes.
I just downloaded droidlive lite which utilizes the shoutcast feeds and the scanner streams run perfectly. Pandora also streams with no interruptions.
I forgot to check the weather or railroad feeds on Scanner Radio, to see if it's a RR problem or Scanner Radio problem. I'll update this tomorrow probably, my phone is charging for rest of work day.
Jason
