F1100DT bandwidth
Tim-B
Down South
In addition to the business frequencies I use for work, I am wanting to program an additional zone into an F1100DT for receive only on local railroad frequencies. I don't see a place in the programming software to set the nxdn bandwidth to 6.25 khz or "VN". Is that necessarily the default bandwidth on the F1100? If it is then I should be good to go or if not then where in the software would I find the bandwidth setting for nxdn? I am seeing it for analog but not for nxdn.
Some of the lower tier Icom iDAS radios only do 6.25KHz "very narrow" NXDN. That radio only does narrow band analog or very narrow NXDN, so that's your only option on the NXDN side.
Tim-B
Down South
Ahh, ok, from looking at the channel spacing of the AAR digital channels it looks like they will be using 6.25 KHz very narrow NXDN so I should be good to go with just programming the frequencies in mixed digital mode and setting the coded squelch type to off so it receives all transmissions regardless if they use a RAN or not.
The frequencies at work are analog FM narrow with CTCSS so I don't need to worry about digital settings there.
Should work just fine.
