BCT15X: Factory Reset
Voyager
Yes and no. It will, but it should give you the option to restore them.
You could simply read your scanner with software first to be sure you save that data.
Many of them are no doubt out of date, though.
Blackink
Central Vermont
Thanks for the link to the State info.
The StatetoState frequencies will not be erased if I reset the scanner. Is that correct.
You are correct.You will not erase the pre-programmed state frequencies by doing a reset.
Just follow the instructions in the link UPMan provided and you should be all set.
Pay attention to where it says To stop State-by-State scanning, repeat the above until all four icons are turned off. Those steps will stop the scanner from scanning any pre-programmed frequencies.
