XTL/XTS5000 Fail 02/90 DSP hardware failure.
oaa
Bygland Norway
My XTS5000 suddenly was dead after charging. After some testing I found out it would only power up when connected to the programming cable. But the prosess could take up to 5-10 minutes, turning on and off many times. When becoming stable I could remove the programming cable and the radio responded to operating the buttons and knobs. It is transmitting but no clear voice heard nor will it receive. Yesterday, suddenly the error message "Fail 02/90" appeared on the screen.. Could it be a bad contact or solder?
oaa
Bygland Norway
Most likely bad EEPROM. These radios are approaching 20 years old, the number of times the chips inside can do background writes is nearing an end.
Would it be possible to replace the vocon board and just put the original codeplug back in it?
