Scanning-NWA
During the last recent Winter event, ARDOT road treating/snow removal traffic was heard on 156.0625 MHz in Benton County for District 9, tonight this is true again. But don't set your PL to only 107.2 (as seen in the database) unless you want to program this frequency in your scanner 3 times. I say this because I had my scanner in PL search mode and I heard traffic on this repeater frequency using different PL's at times - 107.2, 110.9 and 114.8. Today I also heard traffic where two mobile units were conversing on 156.0625 MHz. But both mobile units were not initially using the same repeater location. The mobile on the Cave Springs repeater location (for Benton County) was asked to change over to another repeater location on the same frequency (for a better copy) and refered to it as Gaither (which most likely means Gaither Mountain). My received signal strength for the Cave Springs repeater was full scale and only about half of that then for the Gaither Mountain repeater location. I remember when I used to hear Washington County ARDOT traffic on 151.085 MHz.
