You know you don't have to pay to listen to the feeds right?Just re-upped for a 6 month subscription. Definitely protect your business first, but I wouldn't mind a member feed option that works in vlc
This made my computer lag so bad I had to uninstall it, you'll need a fast and powerful pc to use it.Download BlueStacks on your Desktop or Laptop. Then go to Google Play & Download Scanner Radio & Broadcastify. Works Great. Can also run other things too. like Pulsepoint.
https://www.bluestacks.com
Yup Winamp and VLC work just fine.
Right Click on the listen Icon, choose save link. Save that on your desktop. Click on it. WinAmp should open & play. You will have to save a new one when it stops working. About once a day.
Thank you! I still have no success. I tried using right click on the listen icon and then save to desktop. No luck with Winamp. Next I tried switching my default player to Windows media player and saved the link to the desktop (I've set the WMP file association to use VLC). VLC also failed to play the audio stream. Also, I cleared my browser cache (Firefox) and then tried using Internet Explorer. I even tried to play the stream using another computer that had Winamp installed. Still no luck
Could you test my feed with Winamp or VLC and see if you can connect to my feed? It might be a problem with my ISP. They apply some strange IP filtering rules to my network traffic. Some ports are A-OK. traffic to other ports are intermittently blocked.
Yep it worked for me.
Looks like it's not my ISP. Just tried to connect from a PC at my workplace. (Using a different ISP) Still no luck.
My guess is people are somewhat wary of it. Reason being no activity in their forums for almost a year. No support on the RR forums because Rob is banned. Can't say I can blame them for being a bit apprehensive about the app.Why not use ScannerLive:
ScannerLive (ScannerLive) - Turn your PC into an online-feed scanner to listen to up to 10 feeds as the same time! Official ScannerLive Forum and RR ScannerLive Forum
Lukemester:
Are you using the latest available version of WinAmp, which is shown below? Other members who have this version (including myself) do not get the sync error when using this version via the RR drop down.
