Fiberglass pole advice
harbor-tech
Punta Gorda Florida
I have a portable antenna, tripod and telescoping mast, made up of (3) 8 foot sections of fiberglass tubing, with a 70 cm dipole topping it. The mast diameters are 1.75, 1.5, and 1.25 inches. I currently use 1 foot 'overlap' between sections, for 22 feet effective height. I chose 1 foot overlap because it seems 'safe', but with no hard data to back that up.
My question is: Should I keep the 1 foot overlap, or is 6 inches enough? Or maybe, I am dangerously over-extended, and should go for 18 inches overlap. Does anybody have any experience / advice to share on this subject?
prcguy
Depends on the pole mfr, material thickness, etc. 22ft is not that tall and I would think a 6" overlap or maybe even 4" is fine. I've had several telescoping fiberglass masts up to 33ft that had tapered sections and they only had about 4 to 6" of overlap. I have a 50ft MFJ mast that can be put up with about 6" of overlap but the mast is not sturdy enough for anything more than holding up a vertical wire at that height. If I use about 2ft of overlap on each section it will hold up various VHF/UHF antennas but that has more to do with bowing over the entire length vs strength at the overlap points.
harbor-tech
Punta Gorda Florida
Thank you prcguy! That 4 to 6 inch sounds great! I got the poles from dxengineering, 1/4 inch walls. I've done Ok at 22 feet, and though another foot doesn't sound like much to many, when you're out in the boondocks it matters.
WB9YBM
You didn't mention wall thickness, which probably plays a role in that (at least to a point). I'm not sure if there are mathematical formulae or manufacturer spec's that would mention tensile strength or some such...
It would depend also on wind loading--how much force is applied at a given point and how much leverage is created by a given pole length & wind strength.
