Flat Cable
Grog
Banned
West of Charlotte NC
They used to sell a "jumper" of flat coax for Sat TV dishs that was about 16" and had F connectors on either side. Not the best, but a workable solution.
mass-man
trying to retire...
Parker Co., TX
Is this to get cables in a window??? A tried and true method is to get a piece of plexiglass, the width of your window and couple of inches tall...open the window, put the plexi between the bottom of the window and the window frame, close the window down on it, put weathestripping or even tape on the edges, and off you go. Drill holes in the plexi all day long for as many cables as you need.
I use this method right at the window at my desk, shack and except for the coldest of days, I never really know the thing is there..
N9JIG
Sheriff
Moderator
Far NW Valley
I used to do the exact same thing with a 2x4 that I painted white to match the window frame. Put a piece of weather stripping on both the top and bottom and it worked great, with no problem keeping the 25 below cold out in the winter...
kf4lne
Bristol, VA
Try this: Get a board that fits, drill holes down the center of it, enough for your cables and be sure they all line up along the center of the board and now rip the board with a table saw down the center of the holes you drilled. Line one side with weather striping tape, place coax in the holes and put the other half on top, close window and you are done. Now you can remove your cables and replace as needed. If you want room to expand just drill more holes than you need and plug them with wooden dowel sections wrapped in weather strip tape.
mkewman
Sacramento County, California
is there a way to use "on glass" technology so that inside my apartment, i can hook the little black box on the window up to the scanner, and outside, i could hook the little black box up to a discone antenna.
is that possible? did that just make sense?
