FleetNet TRX 1
FoeHammer
Windsor Ontario
Ok I haven't really done much with the TRX 1 since I got it other than imported from library to make scan lists. I have been playing around with it trying to learn it. Occasionally I did get Windsor FleetNet before and was able to get OPP and EMS. For some reason, I can't get them anymore but it gets other systems and DMR fine.
I see a strong signal on the scan list I have for it, but is doesn't stop or pass audio when my other radios do. I have no idea what I did or what to check to fix it.
Anyone familiar with the TRX , know what I should check ?
FoeHammer
Windsor Ontario
Did you hit the slip button? Are the scan lists enabled?
I'm having a look. The scan list is enabled, it does not appear to be skipped. I see the signal meter , it doesn't stop on talkgroups like old 396 is doing.
I did seem to get it working again by importing the system again into a new scan list, but I noticed something. It would not not stop on a certain tg id my other radio was. That has me wondering how to add a wildcard from the front panel.
I was trying to do that assuming it would receive everything I had programmed plus whatever new tg ids pop up. Maybe that is not how it works.
