Ford Ranger Mobile Install
gfrench
Texas
I finally got my mobile install done.
I just could not find anything that I liked, so I decided to custom make my own radio console.
I designed it so that the CB and my scanner just slide in and out of the cabinet. I am working on my Antenna mounts and will send pics as soon as that is done.
I am running a Qtr Wave and a Antennex low profile for my scanners and a Wilson Cb antenna.
gfrench
Texas
I attached the speaker bracket to the removable insert that is in the cup holder.
There is a lip on the bottom part of that insert, and I just used a couple of nuts and bolts thru the speaker bracket and with 2 larger washers just kinda clamp it to the top lip.
As far as the box, I just drilled 2 very small holes in the floor at the front center and at the rear side inside the box area and used 2 L brackets and a couple of plastic anchors and screws.
When I am ready to take the box out just a little black silicone caulking to fill the holes and you will not even notice.
