Can't offer any insight for Franklin specifically but I've mentioned before that I have noticed with trunked systems changing site IDs that for single site systems (like Franklin, Pitt, Dare, etc) it's a safer bet to run a wildcard "FF" on the site and RFSS for unfamiliar systems on the G5. As long as the system ID matches the Unication will still find the system. System IDs are a lot less likely to change than site IDs in my experience. Same for control channels in poorly documented systems or Harris systems that can use any frequency for control. Setup your known CCs in the list to speed things up then do a full spectrum search as a backup.
Let us know what you find and if you have any luck the next time you visit.
