If you can, I'd run a band specific antenna for the trunked systems and something else feeding the 536. You're in Orange County, correct? I looked at all the systems around you as well as VIPER and the antenna I posted covers those frequency ranges. Were you going to split off and feed both scanners from one antenna?I’m in a rural area with 5 counties that use Apco p25 phase 1 and ll. State police use it as well.
I thought I may get a mobile antenna with nmo mount to pull in those 800 mhz simulcast systems.
I have 2 scanners- Bcd536hp and a new Sds200.
I’d like to use the sds200 for digital stuff and the 536 which has the dmr for stuff in the 400-553 mhz and under range.
I was leaning heavy on buying a Diamond wide ban discone antenna. I’m not sure. More research is needed.
