cpuerror
This new version incorporates bug fixes, new features and general improvements.
FreeSCAN 0.9I
.9I
-New: The old logging system did not seem to receive a lot of love, I have redone the logging
system to be a bit more presentable & user friendly.
-New: Added "Blind Friendly" mode - displays an additional menu in the main editor that allows
keyboard access to certain function that were only available with the GUI.
-New: The GPS entry dialog has been changed to be easier to use. Only one text box to fill out for location,
and the Google maps viewer is now integrated into the form so you don't have to view the maps in a browser.
-Change: The function to lockout all systems/sites simultaneously has been changed to only do one system at once.
This is handy for multi site trunk systems because now you can lock/unlock all sites with one click.
-Fix: Problem logging NACs on 996XT
-Fix: UASD file import causes audio type to be set to Analog on some systems
-900Mhz systems on XTs now downloaded back as 900Mhz systems rather then 800/900 sites to help with cross
compatibility
-900Mhz systems uploaded to XTs will now upload back as 800/900 mhz systems rather then Custom
-Fix: Issue with importing certain rare counties using the RR web service that cause a hangup
-Fix: RR has apparently added a new country to their database. As a result, clicking on the American
flag in the RR import screen caused Uruguay to load up instead of United States.
-Fix: Geocoding functionality has been tweaked to be a bit more reliable.
-Other bug fixes and improvements
FreeSCAN 0.9I
.9I
compatibility
