FreeSCAN 0.9N Available
cpuerror
Ontario, Canada
This version incorporates new features & bug fixes. Visit http://scannow.org
Whats New?
.9N
-A new enhancement has been added to the RadioReference Web Import Service. As we all know,
these scanners have a limit of 20 groups per system. This can be an issue when importing certain
systems because they contain many subcategories that only have 1 frequency in the entire group
and some would consider entirely wasting space.
-A new feature has been added that lets you select the minimum number of channel that should
appear in their own group. For example, if you set it to 3, any group with less then 4 frequencies
will still be imported but its channels will all be placed in a Miscellaneous group.
-This is great for rural areas where you get these behemoth systems that have 30, 40, or 50 groups
with only one or two frequencies per group compressed down to one system with a Misc group that
contains all the respective frequencies.
Larger sized subcategories will continue to be imported as their own groups.
-To activate this feature, click on the Options tab in the RadioReference Conventional Import dialog.
Logging System Enhancements:
*A new tab has been added to the Log Viewer called "Search".
You can use this to quickly query only log entries involving a specific item, such as a specific
channel or a specific frequency. You can also use the search feature by double-clicking on the
specific channel in the "Review" tab and all instances of that channel becoming active will
automatically by searched and displayed.
*You can save and load log files from the Log Viewer. This makes it easy to look up certain
days esp when used in conjunction with the search feature. You can reload saved log files either
from the Log Viewer after starting virtual control, or you can load them up directly from
the System Editor by selecting File * Open.
*Another new feature is Log Auto Save. If you have FreeSCAN logging/recording 24/7, Log Autosave
will automatically save the log file at midnight local time and start a brand new file.
Files are saved either to the My Documents folder or the last folder used to save log files.
The file name is autogenerated for you.
These new logging features are designed to work in conjunction with the built-in audio recording function.
Together, you can load up a log file and instantly look up any channel activity, that happened at any time
recording & logging was active with very little effort.
Other Bug Fixes & Changes
-Fix issue with custom search enabled on/off being flipped around
-Fix an issue with defaulting to COM1 on some cases
-Fixes an issue with warning messages when creating a multi-site LTR system (now possible with XT scanners)
-Motorola P25 Sites have are now called "Mot P25/P25 Standard" to help clarify how these sites function
-Beartracker/POL functions on the BCT15(X) are now automatically disabled after doing a full erase
-Other bug fixes and improvements.
