ratmandu
As some of you may know, I started a web project around christmas for storing, sharing, and easy access to frequency lists online, called FreqStore. I got quite a bit done on it, but started running into walls that I had to work around in the base login system code I was working with. Rather than keep working around my previous code, I have decided to start over, and have the project GPL'ed from the beginning. I have started a google code project for it Here. You can continue using the other one until this one is up and running, as I will migrate over all the information.
If there is anyone out there that would like to help out, let me know and I can add you to the project so you would be able to get access to commit to svn and help out with the coding. And also feel free to add feature requests to the issue tracker for anything that you feel would be useful in it.
