Frequency Help
jocklover26
CLEVELAND,OHIO
I See That On This Site Are Frequencys For The Different Departments. Listed Is The Freq. And Then There Is An Input Freq. Listed. How Can You Tell Or Find Out Which One Is The Tx And Which Is The Rx? Please Help Me Out.
CVPI4Ever
Ohio
Frequency - Rx
Input - Tx
I asked the webmaster, Lindsay C. Blanton III (blantonl) to make this simple by listing Rx and Tx for new folks such as yourself and got blown off on several occasions. Heck, you cant even send him emails or PM's as they are blocked or something.
wa8pyr
Staff member
Lead Database Admin
Ohio
CVPI4Ever said:
Frequency - Rx
Input - Tx
Listing them simply as RX and TX would be confusing. Does it refer to mobile TX and RX, or base TX and RX? The way it's listed now shows base transmit and base receive (input).
Tom WA8PYR
freqhunter
Somewhere in Time....
jocklover
There is a group of us that meet most Friday and Saturday nights to play radio. Most often on the near west side at a 24hr place. Join us sometime. Lots of good info within the group.
CVPI4Ever
Ohio
Tom WA8PYR
Ok t hen make it say Transmit and Receive. That would help. Some folks see input and say, "huh?" I was that way at first.
nexus
Mississippi
Not every agency uses a repeater though... So thats why he has it listed as Freq:
And only agencies who use a repeater have an "input" listed, and "input" is the correct term when you're dealing with repeaters. Because FREQ could also be both transmit and receive.
I know its confusing to someone who isn't a HAM who should know the meaning of input and output.
k8mcn
Old Monroe,MO
to explain, the input freq is "heard" by the repeater, then the repeater retransmits the "heard"
Message on a slightly higher or lower frquency---if you listen to an input, you would usually have to be pretty close to the person transmitting, or have a pretty good antenna--by using repeaters, the transmit receive range is increased dramatically---when or if you listen to any 2 meter or higher traffic on your scanner it is probably coming through a repeater.........
